Charged RTX
does anyone know what % the sheave increases overall gearing? I want to gear down to keep about the same top end potential.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I think its 5% but not sure,but it does help a little.Charged RTX said:does anyone know what % the sheave increases overall gearing? I want to gear down to keep about the same top end potential.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
If you install both the speed sheave and an aftermarket helix which is machined for higher clutch ratio you can achive the same theoretical top speed at approx 21-22/38. Highest stock clutch ratio is 0.97:1. Highest stock clutch ratio whit speed sheave and machined helix is 0.84:1
PS! This may vary depending on centre to centre distance between primary and secondary clutces and the condition of your clutch belt.
Charged RTX
Wow that is about 13% I am surprised it makes that much difference. I have a Super torquer secondary setup that shifts out more than the stock setup. Looks like you could go down to a 21 on top and still not lose any top end. Did you get that info from Hauck.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
No info from Hauck. I have measured how high belt can go in primary and how low it can go in secondary, then with some math I got the figures. With the stock primary sheaves the belt can not shift out all the way up in the primary, it will stop 7 mm below the outer edge. Beeing able to shift out the last 7 mm will make a significant difference in top speed if you have the power and/or clutching to do so. Another way of using this overdrive is what you are asking; gearing down for better holeshot without loss of top end speed. It works if you have traction to take advantage of the encreased torque to the ground.
