Speedo vs. GPS
68gmc
New Brunswick
Canada
Garmin GPS showed 190.4km/h which is 119MPH vs. the max recall. Pretty impressive accuracy!
Just a spike spinning. Clutched for 9000rpm
Ok gotcha....nice
I end up liking 9 to 9100 myself(top) then it seems snappiest at trail speeds corner to corner. Revving any lower on top makes it much less snappy down low then.
Did you say you run stock primary spring(55/105)?
thnx
Dan
Ok gotcha....nice
thnx
Dan
Stock primary spring with daltons set to 80 grams.
Thanks, thats what I thought. And really darn close to where Ive been getting myself.
Im in search of stock(like) rate spring for primary....Im not a fan of how the stock spring is so long and it really binds badly with mine, the glide washers help but would like to try to find something similar to 55/105 from aftermarket that is shorter overall.
Thanks for info ;)
Dan
my btx se is way off 128 gauge 115 mph gps
totally depends on conditions/traction. If on good ice, with good studs or very hard packed snow will little track spin..the speedo gets closer...once you start spinning...difference gets worse.
Mine's 3 to 4 out when running 125 to 130. gps vs speedo. 129" studded very aggressive on bare ice. Seems to be 2mph off when crusing 75-80. The other 129 in our group is the same.
Can you explain how to see PEAK DATA in the left window. Don't believe I have that on my 2017 Winder just RPM recall..
That's a reconfigured gauge from Precision efi. You would have to send them your gauge.
