gordo
Does anyone use one of these:
http://www.yamaha-motor.ca/accessories/ ... model=1982
I was wondering if this bracket will interfere with the use of the windshield bag. It seems to move the speedo pod down and out of harms way which is what I'm after but I would still like to be able to use the windshield bag. I know some are turning the mounting bracket upside down but this for sure looks like it makes the bag unusable.
I was riding with a friend the other day and he flipped his MTX. The windshield and speedo pod both took a hit and broke the plastic around the mounting bolts on the speedo pod. Not a nice sight and I would hate to have it happen to me. Any help would be appreciated. Thanks.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Don't know about the above bracket, but have you tried flipping your stock bracket upside down? That should drop your gage a few inches and save you close to $80.
gordo
I thought about doing that but would it not prevent me from using the windshield bag?
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Yes it will interfere with the windshield bag.
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
i put my gauge pod on top of the head light cover just had to drill 3 holes and a 1 1/4" hole in the middle for the wires to go through and my the boot into it looks sweet in that location
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Yep, any of the gauge relocation brackets will prevent you from using a windshield bag. I bought this roll over bar so I could use a windshield bag. Haven't tested it yet though
. G.B.
http://www.schmidtbrosmotorsports.com/y ... l-bar-kit/
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
When I relocated the gage from the dash to my handlebar riser on my Nytro, I used a Phazer bracket. I cut a piece off the bracket, couple of inches maybe, so that only one hole would be available to bolt it to the riser. If you did the same on your Phazer, you should be able to lower it some. Take a look at your sled to see if this is feasible.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Or you could relocate the gage to the "rider side" of the handlebar risers. I have my gps mounted here and it seems to be protected from a potential rollover, works well.
gordo
Thanks guys for the different ideas. I'm not sure which way I'll go yet. I hate to blow $80 on a bracket and it not do what I want.
