Nytro08
- Feb 3, 2019
- Albany ,ny
- 2008 Yamaha nytro
I just picked up pair used split rail skis . My sled is a 08 , 09 and newer sleds you can bolt them up and ride Per split rail via email ,since mine is a 08 I need to align the skis. I asked for suggested alignment specs and never heard back from them . Does anyone have know what I should have them to ? Thank you in advanced .
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
With single keel skis you typically want more toe out than dual keel or dual carbide runners. The Split rails don't need a large amount of toe out with the two keels. I would set them up around 1/8 to 1/4" out. The difference between the 08 and 09+ Nytro is the mounting location for the tie rod ends on the OEM spindles. Because you're replacing the stock spindles with the split rail spindle the toe needs to be checked and adjusted. Don't get carried away with trying to be exact with this setting. Usually there is to much play in the steering components and front suspension to be overly precise and toe settings can vary due to ski/carbide/suspension setups and rider preference.
Nytro08
- Feb 3, 2019
- Albany ,ny
- 2008 Yamaha nytro
Nytro08
- Feb 3, 2019
- Albany ,ny
- 2008 Yamaha nytro
Yea this is what they sent to me
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
That's an interesting statement made in that last sentence. I, and I believe many other Nytro owners would disagree.
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
Haaa...I just read that last sentence and had a chuckle tooThat's an interesting statement made in that last sentence. I and I believe many other Nytro owners would disagree.
- Jun 28, 2004
- Clinton, Wi.
Hmmm, pretty ballsy statement. How many aftermarket front suspensions are there? 4,'5? Mine has the factory team front end on it.
