darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
Hi i just purchased a 08 Apex LXT GT and my weight is 325 with all gear my sled comes with a 6.1 spring i know that will to lite i call carver performance and he was not sure so what are you guys using should i just order the 7.1 the big one yamaha has in the accessories catalog thanks for help.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I use the stock one and I come in at 330. And I made my a sled a 144" with a 136 skid in it and it ride nice and hard
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Carver has some really good performing valving mods for the Ohlins shock that's in your LTX GT mono skid. He usually recommends sticking with a lighter rate stock spring with his valving specs. I'm currently running his set up using a 4.9 spring on a 136" mono skid with quite a noticeable improvement in ride quality over the stock set up. I'm a wee bit lighter rider at 150 lbs.
With his valving specs and your weight, I'd start with the 6.1 spring that you currently have, and see how you like the ride before going to a higher rate spring.
Tattoojunky
- Oct 16, 2009
- Highland Lakes, NJ
- 2007 Attak GT, 2023 Sidewinder L-TX GT EPS
Go Big Boy!!!
I go about 325 all geared up, so I went for the Big Boy spring straight from the dealer when I bought my 2007 Attak GT, and I have not regretted it one bit. Sure you could probably get by with the stock spring, but if you plan on packing any additional gear for any long trips or have to double up when the old lady decides to take that one or two rides a year you won't regret the upgrade.
ahicks
The spring holds you up, the shock takes over from there. You need to set the sled up so the ride height is within specs to start. (I would endorse setting it up within specs - but near the very top of the range provided.) Then you send it out to be revalved. Switching springs AFTER a revalve pretty much blows the custom valving. The rebound damping will have changed for sure - especially going with a stiffer spring.
Carver's recomendation is assuming this logic. If you decide to go with heavier than needed springs, I'm sure he'll compensate, but there will be no doubt about the results. The ride you get out of the deal will be stiffer than necessary.... FWIW
- 30K
