Spring rate on the Ohlins setup
RX1Jim
Poughquag NY
Does anyone know the spring rate of the springs that are on the Ohlins setup for an RX-1? I am planning on installing the Ohlins but want to know the spring rate. I plan on using them with a Pioneer 12 mm dia. sway bar and the longer sway bar links. Thanks!!
I don't know the rate I just jacked the front off the ground ran the ring down to the spring top added 1/4 turn and then adjusted from there on my 2 sets.
