Sr Viper Headlights
Not enough! (Lol) I've never seen a number assigned to the stock light but I can tell you it's not great. To be fair I believe the biggest problem is the split between the hi and low beam patterns is to great forcing you to comprimise between the two. If you aim it for the low the hi is in the trees and if you set it up for the hi the low is only about 20 feet in front of the bumper. Roc sells a remote adjuster that makes it easy to adjust the light but the best improvement you can make is to add his HID kit in my opinion. I now enjoy riding at night again.
I've heard nothing but good things about Rock's stuff but I went with a set of LEDs from superbrightled. Much brighter but still need to do some trail testing as I installed them over the summer thanks to the reco of one of the members here.
Not enough! (Lol) I've never seen a number assigned to the stock light but I can tell you it's not great. To be fair I believe the biggest problem is the split between the hi and low beam patterns is to great forcing you to comprimise between the two. If you aim it for the low the hi is in the trees and if you set it up for the hi the low is only about 20 feet in front of the bumper. Roc sells a remote adjuster that makes it easy to adjust the light but the best improvement you can make is to add his HID kit in my opinion. I now enjoy riding at night again.[/
Thanks for the info. What is the website for the HID kit? What is the major difference between the HID and the LED?
