stabalizer link question
snowrules
Ottawa, Ontario Canada
Have a 2003 rx1 i've heard alot about updating or adding a performance sway bar link. my question is how can i tell if the guy who had the sled before me has updated it or changed it already?
measure
Measure the links I think the longer ones are 75mm, check pioneer performances website i think it gives the length there for the longer links, the stock sway bar was 10 mm diameter and there are 11, 12, and 13 mm replacements, if you go over the 11mm you need bushings I just ordered a 12mm bushings and links from pioneer for my wifes 03 that I am rebuilding.
I measured mine and my measure 75mm center to center and near 100mm end to end. I was told mine are the longer updated ones
link,s
if you go with a larger sway bar you may have to buy new link,s any way as the 03,s have a step on the end,s of the bar,s and link,s that later model,s dont have so the link,s wont fit the larger bar. on my 03 that, what i had to do and the stock bushing,s worked with the 12mm bar. as the 10 mm bar had a lager diameter at the bushing loction.
