ChiefMn
- Aug 25, 2013
I would think that should be plenty. You have it being reinforced on two edges plus bolting in the skid will also fix it in place. Mine is the older style
Hannibal802
- Feb 19, 2020
- Vermont
- Nytro
So I've finally got around to pulling the skid, I just want to make sure I'm doing this correctly before I go cutting rivets and drilling holes. It just lays over the top of the existing plate I assume. Some of the rivets line up, I also assume I add ones in places where holes are drilled
Hannibal802
- Feb 19, 2020
- Vermont
- Nytro
I figured out what rivets come out, but I'm not certain I have the washer in the correct spot. Are you supposed to relocate the bracket for the front skid to the new hole? You get 1 washer per side, 1 bolt and nut, and rivets which I'm using and obviously the bracket. I thought the washer was used as a spacer to go behind the bracket as seen in the photos below, but now I'm not certain. I would think you'd want something on the front but maybe the tunnel reinforcement plate thats already there is enough?
Seavey82
- Oct 27, 2017
- Maine
- 2013 Nytro XTX 1.75
Did the relocate kit not come with any instructions or something? It seems like these details should be laid out for you in the instructions. Not being sarcastic just wondering.
Hannibal802
- Feb 19, 2020
- Vermont
- Nytro
No, no instructions came with it. Went to their website and theres nothing there either.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
It’s been awhile but I’m pretty sure when I did mine I put the washer in between the tunnel and plate and moved the factory bracket to the new location like in your last pic.
bmazbnytro
It’s been a few years since I did mine. The rear bracket in question looks just like mine. I didn’t get instructions either, I had to call and they emailed them to me.
Hannibal802
- Feb 19, 2020
- Vermont
- Nytro
So the answer I got was the flat washer usually goes on the outside of the tunnel in the new front skid mounting spot, they don't care about the gap left between the plate and tunnel on the front skid bolt on the inside but putting the washer behind it is fine, could make the suspension install a little tighter but shouldn't be an issue. They don't move the triangular plate, but I've already relocated it so I'm not going to worry about it.
