frano
I drained the carbs & fuel from my '05 Rage last March and decided to start it today to get it ready for Winter. It took a lot of cranking to start. On my 2 strokes, I would put a couple of tablespoons of gas directly into the cylinder and it would start quickly. Is that the trick for the 4 strokes also?
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
bsevigny
- Mar 25, 2006
- Minnesota
- 2016 Vector XTX 1.75 LE with Elka Shocks
2013 Vector LTX
2016 Polaris Assault with 159 track and 35" front
2009 Polaris RMK 700
I put two gallons of fresh fuel in the empty tank. Then take off the air box cover and put a couple of teaspoons of gas in the snorkel of each carb. It will fire and die. Do this a couple more times and it will run.
Bgs
Bgs
twomorestrokes
Try LazyBastard's tip that is outlined in the link that Freak supplied. I read that a few years back, and that's how I've been doing it since. It is much easier than removing the airbox and spoon feeding the carbs. It just takes a minute and it starts right up like it normally would during the season. I was impressed.
willie42
try new plugs. I had simular start issue and this was the fix.
Budweiser
LB tip has worked for me every time. As soon as you start blowing it starts firing.
rodehard
- Jul 6, 2007
It is amazing how well LB's solution works and how few yammie experts know about it. It makes sense. Its just like squeezing the bulb to "prime" the fuel on other small engines.
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
I just tried the trick and the sled still refused to fire. After some serious head scracthing I remembered I had siphoned the tank dry last fall - jokes on me. Took about four 4-sec cranks after putting in some fresh gas (and blowing into the hose) and she was back to life after a long summers slumber.
twomorestrokes
pdiddy said:I just tried the trick and the sled still refused to fire. After some serious head scracthing I remembered I had siphoned the tank dry last fall - jokes on me. Took about four 4-sec cranks after putting in some fresh gas (and blowing into the hose) and she was back to life after a long summers slumber.
Hahahahahaha! Took some guts to admit to that one!
Sounds like something I'd do...
Mike
