Starting problem
kingston phazer
Scotts Michigan southwest lower
i have a 07 fx, and i have tried to start it and thought the battery was dead, so i put it on a optimate 4 battery charger and it charged fine then test with a volt meter and read 13 volts...i think i have an idea of what it is probally the starter relay but an ideas would be helpful.
Thanks:Kingston Phazer :yam:
Check for moisture in the relay, or your starter could be screwed and needs to be rebuilt. Can you tell us whats its doing specifically?
Let your relay dry out and if that don't help, then check this thread. Your starter may need a rebuild. It looks like a lot of work, but can be done in a day. The starter doesn't need to be replaced, just re-clock the sections and LocTite the bolts that hold the whole thing together.
I think its right in front of the battery? I can't remember so someone else should confirm this.
