- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Don't forget to locktite those starter bolts!
zackn291
they back out quite abit?
- Nov 1, 2009
- 2009 Phazer RTX
Yes, make sure its also all aligned properly, I think it a green line.
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Yeah, as long as you have the starter out, you might as well check the marks and loctite the botls.
zackn291
whata this alignment crap yall are talkin about and green lines?
- Nov 1, 2009
- 2009 Phazer RTX
zackn291
thats for when you take the starter apart. im not taking mine apart
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Yes, but those screws have been known to loosen off.........
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
yeah
zackn291
I have a feeling if i tampered with it, it would fall apart 400km into the season.
Ive got 14000km on her so far and it hasnt fell apart. I dont want it to fall apart this season.
zackn291
new relay works! time to put it all back together
- Nov 1, 2009
- 2009 Phazer RTX
zackn291 said:new relay works! time to put it all back together
zackn291
alright so quickly went home on lunch to get see if the sled starts. got my oil tank from being welded..
cranked my sled and the relay goes.... "click..(followed by) BUZZZZZZZ ERGHHHHHHHHHHHHHHHHHHTGOHJTROGJHRTSHGJR:BQRTWOG$OJTRG" and thats it. the speedo flickers a little bit and what not but the start dont crank or nothins.
any ideas?
any ideas?
Jeffz
- Feb 3, 2010
- Cresco, Iowa
2007 Phazer "RTX"
Sounds like the starter has rotated out of phase. You should have checked that while the subframe was off.
zackn291
That doesn't make sense cause the starter worked before I put it all back together plus the relay makes crazy noises...
