Burntlandsbandit
I am replacing the stator on a 2008 vector, i have all the bolts that hold the stator cover on removed but the cover feels like it is attatched via a spring loaded something on the inside, i see no reason it shouldn't just come right off in the manual, whats going on???
Zifto
- Jan 16, 2005
- St-Georges Beauce, Quebec,Canada
There is a magnet inside the cover. You'll have to pull it hard.
srvfan
- Nov 9, 2004
Thought that was only2005-07 thought they updated it?
Burntlandsbandit
Thanks, it was just the force of the magnets that was holding it, unbelievably strong..... anyhow stator is out and burnt like a crisp...
YamahaHoss
- Mar 23, 2020
- Wisconsin
- Yamaha RS Venture
How did your stator replacement go? I have an 06 and have to do the same. ANy tricks you found out or learned? ALso any great sources or vidoes on how to do did you find?Thanks, it was just the force of the magnets that was holding it, unbelievably strong..... anyhow stator is out and burnt like a crisp...
