ROCKRTX
just check the yamaha parts on line to get the numbers just did mine when i did th e exhaust .
i think they are around 20ish each
ROCKRTX
Thanks i just found it.
POB88
Try here...27% off
http://www.yamahasportsplaza.com/pages/ ... fault.aspx
apltx08
The slack/play is mostly coming from the steering POST, I'm going to pull the steering post BUSHINGS out and grind the spacers down to THIGHTEN them up and add ZERKS to make them greasable, just move your bars back & forth and you'll see a LOT of movement at the bottom of post...
ROCKRTX
Yes you are right i got movement in steering post,i also ave a lot of movement on the column beside the oil tank.
So i guest i'll wait to order tie rod and just grind the bushing and see what it does.
apltx08
ROCKRTX said:Yes you are right i got movement in steering post,i also ave a lot of movement on the column beside the oil tank.
Yes you'll see a BIG improvement and ZERK them at the same time
Let me know how you make out...
