new rob
- Oct 18, 2009
- peterborough ontario
- Viper rtx
What is best way to remove the warning stickers from tunnel and panels . Hair dryer and goo gone ??
Super Sled
- Feb 25, 2009
- Summit X
Heat works best, then some adhesive remover if any remained.
Hot water will loosen the adhevsive and also help it from not re attaching
A really neat trick I tried yesterday, and it actually worked! Baby oil!
I've ruined many a windshield over the years trying brake clean, carb cleaner, and lots of other products out of a spray can as well as lacquer thinner and xylene. All worked great at removing the adhesive, but would cloud the lexan.
Once you peel the sticker but have some adhesive left, try a cloth with baby oil on it. It takes a little elbow grease, but it does remove the glue and not wreck the plastic.
Not necessarily applicable to an aluminum tunnel, buy way to neat a trick not to share on windshields and other plastic parts.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Heat and then use WD40 to remove the residue. G.B.
Daranello
Suspended
doesnt WD40 ruin the plastic, take away the shine??
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Try Goo gone or goo-b-gone. Something like that. I have had great luck with it to remove the remaining adheasive.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have never seen WD-40 remove the shine on anything. im prety sure it is safe to use anywhere on your sled.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Just use a micro fiber cloth and it shouldn't haze the finish. Goo gone works well for me
new rob
- Oct 18, 2009
- Viper rtx
Which ones do you have to leave on the tunnel??
s1d3w1nd3r1480
I have used WD-40 on many a things without any negative consequences, wouldn't hesitate to do it on the tunnel however on other areas I always prefer the idea "better safe then sorry" so I will test it on a small spot hidden somewhere. So far though as I said I have not encountered any ill effects.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
new rob said:Which ones do you have to leave on the tunnel??
If the sled is new, then the dealer's/manu's have a legal obligation to have them there, but once it's sold then the new owner is pretty much free to remove what ever he wants. (double check first though)
I also use heat and WD-40, or Goo be gone, or peanut butter or Mayonaise. Usually anything that has oil in it will work but I prefer WD for than and that only.
- 7K
