rx1 fern
what is the base weight of the super tip weights people are using on their vipers .thank you
I believe they are 52g. I went with the Ulmer setup on mine.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I believe most are using the 60g base weight. I have in all my turbo sleds, 5-17 psi.
rx1 fern
i have the 60 gram base weights .was just curious to see if they would work on my viper without a turbo
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
I have them in my Viper without a turbo. The Ulmer kit.i have the 60 gram base weights .was just curious to see if they would work on my viper without a turbo
rx1 fern
yeah but what do your weights weigh empty .mine are 60 grams empty .was just wondering if i can get these to work on my viperI have them in my Viper without a turbo. The Ulmer kit.
Nytro40th
- Sep 19, 2007
Mine are 50gm but I have a lot of weight added, heel 1 tung 3 washers, middle 0, tip 1 washer, tungsten alone is 7 grams I believe.
