Northernboy
Just wondering if it is worth it to mount the stock air temp sensor in the intercooler?
To me it should be measuring the air that is going into the engine and not the ambient air temp.
Jona$
Master
- Sep 27, 2010
- Northern
- Sweden
- Tapex/sks 800 -16
good question, would love to hear a explanation from some turbohardheaded.
gunnerthesnowman
Northernboy said:Just wondering if it is worth it to mount the stock air temp sensor in the intercooler?
Yes it should be mounted after the inter-cooler , before the motor
Northernboy
The problem I see with mounting the sensor in the intercooler is as air temperature goes up it would lean out the mixture thus making it more prone to detonation. Is this an accurate theory?
gunnerthesnowman
Northernboy said:The problem I see with mounting the sensor in the intercooler is as air temperature goes up it would lean out the mixture thus making it more prone to detonation. Is this an accurate theory?
What turbo system are you running , what fuel box , I run a vipec standalone and my map is made for my sled with AIT correction , if I remember right with my Alpine turbo kit with the pure logic the air temp. sensor was mounted ( zip tied ) just under the hood .
FLYBYU
If your running a piggyback system it should be in the intercooler as the factory ecu is still reading it. I'm running a standalone system and it still needs to be in the intercooler.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
If this is a off the shelf turbo kit like MCX it is installed outside the IC to read ambient outside temperature.
Custom systems With standalone ECU computers are designed to run the sensor inside the IC using the sensor input.
MCX and most turbo kits do not have this capability.
Northernboy
Also stock sensor were probably not designed for higher temperature so that's why most turbo companies recommend mounting outside to read ambient air temperature.
I'm going to mount a temperature sensor in my intercooler and tie it into my data logger to see how hot it actually gets.
FLYBYU
When i bought the cpr kit, he had the bung on the intercooler for it.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Doesnt Powderlites intercooler for the Nytro have the sensor in it?
