Stock clutching??
THEROOKIE
Newfoundland
Can somebody please tell me the stock specs on the 2009 FX Nytro RTX SE and also the stock clutch specs for the 2009 FX Nytro XTX. What I would like to know is the primary/secondary springs, weights(rivet grams) and the helix angle.
No info, I thought someone posted the specs last fall, I have used the search function with no luck.
I thought srxspec posted the info last year?
I believe this is what your looking for?? Not sure though.
Reduction Ratio: 21/39
Primary: 90501-582L1
Weight 10.3 out, 17.2 center, 17.2 in
Secondary: 90508-60012 w 43 deg cam angle and 1mm shim
