Turks clutch set up
uofm
Tawas City, Mi
He had a set up using stock weights with a 47 degree helix what is the secondary wrapped at? What primary spring?i cannot find any information on the settings. Thanks 2009 xtx also what are you putting for weights in the shoulder , middle, and tip
everything that I have found about his setup was with drag and fly clutch weights, sorry I cant help with stock weights.
I used that set up on my RTX with the stock Y-S-Y spring.
mx1500 said:
whats a good set up for catwalking? like bigger weights oirrrr????
I think a Turbo would be the best set-up :moon:
Adjust your transfers in the rear of the skid. But don't use it for trail riding.
