kinsound
Looking for media clips of the sound difference and or opinions on replacing stock with Hauck....I want growl but not want to be obnoxious..
rage man
that hauck is good i have it on my rage i like it i dont find it loud but im young and we all know how loud young guys like there stuff
p0wd3rp1l0t
im the same with rage man...loud but not too loud..only thing is u cant run studs..even if u have tunnel protectors
Oak Hill
I ran studs in mine!
p0wd3rp1l0t
well i ran mine and it chewed a hole threw the pipe...and i had to replace it. so i would suggest not runnin studs with this pipe...and the same on my dads 04 rx1 with a hauck pipe
rage man
i run studs
p0wd3rp1l0t
check ur pipe then....and u will have a bunch of scratch marks in it...unless i bottom out a little more than everybody else
Oak Hill
I have a few scratches on mine. If you run your track loose, the studs will hit the exhaust. Remove the studs from the center and your good to go. I just love the sound of this pipe and weight difference.
onlyblue
the hauck pipe does sound good, i have personally heard pimps and his dads, both sound great... they have that low growl to them, not like the tinny sound of the whitknuckle....
my choice would be either the hauck or the excell for sound.... (i like the looks of the excell the best, but very pricey, that is on my wish list for my attak)
04yamaharx-1
i agree..I have a hauck exhaust on my rx-1...It sounds awesome..the studding hasn't been a problem either....as long as you rivet slides on top of your tunnel protection. It gives it a little bit more clearance for your studs!
kinsound
Thanks for all the input...The Hauck was no longer avail so I found A gutted Stock pipe.....we will see how that goes
