z06vette1
what is the stock setting on the 07 attak?
dlange
I believed they veried, but mine was at center,
SharkAttak
my 06' was in the center and i went up one hole (tightened)
Daranello
Suspended
My 2007 Attak ER was in #2. Now I changed it to #3 center
AllagashX
my 08 ltx came all the way loose
limiter
My 07 came top hole. LOOSE I am not sure the dealers set these sleds up
at the time of sale.I think they should take the time to show you or at least set the sled up for you. My sled is still not set up right for my style
of riding or my weight.Buy what I have been reading a 300 lb. man cannot
obtain proper setting without spending a bunch of money and tearing sled apart redoing everything.I believe the dealers should tell the customers
this before they sell you the sled.Also if I buy another sled you can bet the farm it will be set up for me at the dealers expense or no sell.
THANKS GARY. PS I feel better I have been wanting to say this for awhile.
SharkAttak
i have had good luck with going up one hole on limiter strap, from the center position which is #3 hole, now at #2 hole, less wear on hyfax and the ski's down lift as much
Daranello
Suspended
SharkAttak said:i have had good luck with going up one hole on limiter strap, from the center position which is #3 hole, now at #2 hole, less wear on hyfax and the ski's down lift as much
You mean hole #4 (#1 being the losest #6 being the tightest)?
SharkAttak
Daranello said:SharkAttak said:i have had good luck with going up one hole on limiter strap, from the center position which is #3 hole, now at #2 hole, less wear on hyfax and the ski's down lift as much
yes, i'm sorry #1 being the loosest to #4, i was going from top, isn't there only 5 holes total?
