ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Could you tell me if the tune effected your fuel milage much?I have 1500 miles on the Evo stage 1 tune. Very happy
lakercr
Tech Advisor
- Aug 12, 2003
- Winnipeg, Manitoba
- 2025 SRX
I've gone from a 1.95 to 1.85 gear ratio with the Evo stage 1 tune. Rode 97 miles last weekend after filling up and still had over 1/4 tank left. I have no complaints on the mileage.
The sled pulls harder in the mid, and is about 10 MPH faster now (6-8MH with just the tune). I've done many long pulls with my setup, and it has been flawless.
Out yesterday for a ride and did a few WOT pulls. 120MPH GPS in heavy wet snow (temps were +6c/43F. Engine was always between 164-177F.
69redmach!
- Nov 27, 2016
- Loudon
- 2017 Sidewinder LTX SE
Pretty much stayed the same.Could you tell me if the tune effected your fuel milage much?
I average between 12.5 and 15mpg depending on how aggressive I ride.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I am quite envious of your power and mileage. Glad to hear about that nice combination.
jdm
- Mar 17, 2004
- Lake George, NY
- 850 G4
- Lake George NY
What clutch setup are you running--great results !!I've gone from a 1.95 to 1.85 gear ratio with the Evo stage 1 tune. Rode 97 miles last weekend after filling up and still had over 1/4 tank left. I have no complaints on the mileage.
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
TPI weights and spring (plus glide washers), with 3/4 allen in heel, 3/8 & thin washer mid, 7/16 tip. Spring pocket in secondary is cut .070, stock cam at 60, offset 60.7mm. 8JP belt.
jdm
- Mar 17, 2004
- Lake George, NY
- 850 G4
- Lake George NY
Thanks--already have the TPI kit, so EVO stage ! tune should be the ticketTPI weights and spring (plus glide washers), with 3/4 allen in heel, 3/8 & thin washer mid, 7/16 tip. Spring pocket in secondary is cut .070, stock cam at 60, offset 60.7mm. 8JP belt.
What is your target shift RPM? Gear Change for 1.85 ratio?
tx
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
Shift at around 8800, and then RPM climb a few hundred on WOT. 22/41 = 1.86
This is what it looks like:
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
is that the cat top gear then? stock chain? (like the less dog leg)
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
Me too - bigly. Lot of people are saying that less dog leg is good, I can tell you that.
I've got to stop watching CNN.
Yes, that's the cat 1702-395 22T gear. Chain is stock.
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
What does it do?Me too - bigly. Lot of people are saying that less dog leg is good, I can tell you that.
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
More efficient
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
Stock is 21?More efficient
lakercr
Tech Advisor
- Aug 12, 2003
- 2025 SRX
Yup
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
yes you should cnn=fake news
is that gear cintered/powder metal or billet
fwiw, some say the lower ratio is harder on belts for those reading...
