ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Could you tell me if the tune effected your fuel milage much?I have 1500 miles on the Evo stage 1 tune. Very happy
I've gone from a 1.95 to 1.85 gear ratio with the Evo stage 1 tune. Rode 97 miles last weekend after filling up and still had over 1/4 tank left. I have no complaints on the mileage.
The sled pulls harder in the mid, and is about 10 MPH faster now (6-8MH with just the tune). I've done many long pulls with my setup, and it has been flawless.
Out yesterday for a ride and did a few WOT pulls. 120MPH GPS in heavy wet snow (temps were +6c/43F. Engine was always between 164-177F.
69redmach!
- Nov 27, 2016
- Loudon
- 2017 Sidewinder LTX SE
Pretty much stayed the same.Could you tell me if the tune effected your fuel milage much?
I average between 12.5 and 15mpg depending on how aggressive I ride.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I am quite envious of your power and mileage. Glad to hear about that nice combination.
jdm
- Mar 17, 2004
- Lake George, NY
- 850 G4
- Lake George NY
What clutch setup are you running--great results !!I've gone from a 1.95 to 1.85 gear ratio with the Evo stage 1 tune. Rode 97 miles last weekend after filling up and still had over 1/4 tank left. I have no complaints on the mileage.
TPI weights and spring (plus glide washers), with 3/4 allen in heel, 3/8 & thin washer mid, 7/16 tip. Spring pocket in secondary is cut .070, stock cam at 60, offset 60.7mm. 8JP belt.
jdm
- Mar 17, 2004
- Lake George, NY
- 850 G4
- Lake George NY
Thanks--already have the TPI kit, so EVO stage ! tune should be the ticketTPI weights and spring (plus glide washers), with 3/4 allen in heel, 3/8 & thin washer mid, 7/16 tip. Spring pocket in secondary is cut .070, stock cam at 60, offset 60.7mm. 8JP belt.
What is your target shift RPM? Gear Change for 1.85 ratio?
tx
Shift at around 8800, and then RPM climb a few hundred on WOT. 22/41 = 1.86
This is what it looks like:
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
is that the cat top gear then? stock chain? (like the less dog leg)
Me too - bigly. Lot of people are saying that less dog leg is good, I can tell you that.
I've got to stop watching CNN.
Yes, that's the cat 1702-395 22T gear. Chain is stock.
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
What does it do?Me too - bigly. Lot of people are saying that less dog leg is good, I can tell you that.
More efficient
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
Stock is 21?More efficient
Yup
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
yes you should cnn=fake news
is that gear cintered/powder metal or billet
fwiw, some say the lower ratio is harder on belts for those reading...
- 10K
