RTX Meirda
ECP kit owners:
What does you RPM's jump to with stock clutching?
Mine goes to 9500 and climbs to 10000 by 90 MPH on the speedo.
I wonder if my stock primary spring is weak.
I am going to start clutching now and I am just curious. I do not want to purchase a new stock spring just to try it out and then change it right away.
Blue shadow
Did you try the oso primary spring?
RTX Meirda
Not yet....I am waiting for the rollers.
Blue shadow
What type of racing are you doing,and how long?
RTX Meirda
Just screwing around.
2000 ft radar runs and racing buddies from a rolling start.
Skydog
Did you lose RPM with the kit?
Blue shadow
I am just set up for 800 ft runs.
RTX Meirda
Skydog:
No I did not loose RPM....it is the same.
They say that you should install a new Primary spring every year.
This is the 3rd year for the sled with the same spring.
What I do not want to do is change to a different spring rate and then say " ït fixed my RPM's"
I am not giving a new stock spring a fair chance!
Since I will not be using a stock spring in the future....I do not want to go buy a new one just for one day an the trail.
What I am trying to do is record some clutching notes for my reference in the future.
I want to make sure that all of my data is correct.
Clear as mud.
Clear as mud.
