chrishall
I have a 2005 RX1-ER with 1800 miles on it.
All clutching components are cleaned.
Primary:
40-20 Heel-Clickers II (No extra weights added) with supplied White spring.
Secondary:
50-40 Helix, Green spring twisted to 60 degrees.
New belt and battery.
Track is not too tight.
Thanks in advance,
Chris
PS
Even stock this sled only ever hit 10,000 RPM's.
Primary:
Secondary:
Thanks in advance,
Chris
PS
Turk
Tech Advisor
You need a lot more secondary spring pressure & less helix. Try a silver at 80; green is nowhere near enuff. Those weights are aggressive; even on a turbo sled.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
you got to use the white sec sprin at 60.
chrishall
I have the stock Pink Secondary Spring. Would the Pink Spring at 70 degrees be close to the White Spring at 60 degrees?
Or are talking about the Heel Clicker sold separately White Spring not the Yamaha White Spring?
Cheers,
Chris
Cheers,
Chris
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
Yes it can go , i´m trying to dial in my new warrior 06 with HC and im not using the HC spring and you dont nedit im using the G-P-G spring and it´s working realy god 3500 engagment and 10200 top end stock helix and withe sec spring total wegith of 63 g.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
Sorry wrong spring thats the one i´m using with HH, It´s O-P-O.
