Storage Bag
vbmike
Buffalo
2006 Attak
That's what I thought from looking at them. Would you say twice as much or half again as much?
How well does the yamaha bag stay in place?
Yes, I would say double of the tunnel bag. It stays in place just fine unless you put the cam locks on backwards. Then it turns in what BOUNTYHUNTER calls a Dandelion and goes POOF as the track eats it up.
Was not me but another unfortunate member of our group.
DON'T use a Skinz bag unless you want everything in it soaked. I use the Yamaha combination bags and ziplock bags with the air squished out of them. I've even put a pair of slip on shoes and an extra pair of jeans in the nose of the sled. I also run full time with a Yamaha tank bag for extra miscellaneous items. Pack for a week no problem.
The Yamaha bag holds more.
You may want to put a bungee or 2 around it if you load it up.
Once 1 of the straps loosens a bit, it doesn't take long for "Dandelions", which i've seen 3 times in my day.
I have similar bag on my Nytro, works great, pair of shoes in each side, jeans, shirts undies an sox. Good to go.
Plastic bag liners be good just in case.
I have this saddlebag that’s never been used. I know it will fit a 08 Apex because my friend has the same bag.
I sure it will fit other Apex models. If your interested PM me for price. I have no use for them so price will be VERY reasonable.
Any bag that is a soft bag will require a waterproof spray to seal it up. We also put our cloths inside of plastic bags to keep them dry.
This is the yamaha bag on top and a gears universal set of saddle bags on the bottom.
Lots of room with this set up for a week including a pair of shoes.
