Mark O
I know that there's no storage on the RX1, but there must be a place to tuck your registration & tool kit. I assume there is a tool kit that comes with it.
Not to sound like an ignoramus here, just inquiring.
Mikey
It comes with an underhood toolkit with some added storage but you will never need it unless your riding buddys need to borrow your tools.
LazyBastard
A hint about the tool kit. Take out the two 22's and put in REAL ones that won't bend when you use them. They are the ONLY things in the kit that you will ever use.
Tom-RX1
The only tools i used were the 14 mm while out and the sparkplug while in the garage .
Tom-RX1
Tom-RX1
Power-Rush
I bent the 22's the first time I tried to adjust my tranfer rods on the trailLazyBastard said:A hint about the tool kit. Take out the two 22's and put in REAL ones that won't bend when you use them. They are the ONLY things in the kit that you will ever use.
Silver
Buy the quick nuts and then throw out those 22 mm wrenches.
A
Anonymous
Power-Rush said:I bent the 22's the first time I tried to adjust my tranfer rods on the trail![]()
Maybe all the ice and snow under your track didn't help the wrenches out any. But they are pretty cheesey...
When I went to see the 05's in Grand Rapids mi I didn't know I would be buying one. So I didn't pay much attention to a lot of things. Storage is one of them. It sounds like ther isnt much storage space on the RX-1. Would ther be room for gloves or a flannel shirt?...thanks...
jimmie d
The optional windshied bag works fine for smaller items but for any bulk you will have to go with something larger.
Jim
Jim
SoCoRX1
hell i did too! Tried to adjust the transfer rods and they WOULDNT spin, so i said screw it.
dealer mechanic said he modded my machine up and had the transfer rods as tight as they could. Thats just great
Mikey
Not to mention the fact that yamaha red locktited the control rod nuts from factory. No wonder you bent the wrenches I had to use two 12" cresent wrenchs to unlock mine once i did they adjusted fine with the factory wrenchs.
Power-Rush
i managed to get one side done but when i tried to do the other
side the wrenches went from being 22' to 24's. next season i'll
have the quick nuts.
Birdman
lack of storage was the bigest complaint I had about the RX-1 until I ordered the tank bag, problem solved.
Phantom
Did you order a Yamaha tank bag and do you have any photos of the sled with it on?
I just ordered a Rage and storage is my main concern with the sled, we leave for rides in the morning and many times return after dark.
I need somewhere to stuff extra gear for use as conditions change throughout the day.
Tank bag is the way to go. Just be sure you glue some felt or other padding to it to protect the gas tank cover. I would have thought Yamaha could have done this when they made the
thing.
