tileman
I want to put a 136 Cobra track under my RTX . MY question is will the proactive skid handle the added length ?I ride mostly Tug Hill can I get away without studs with the cobra? I currently have 144 Woodys in my Ripsaw.I would like to not have to worry about front heat exchanger but also want to be safe and hook up. sled only has 600 miles on it
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Its a good track for lose snow more then hard pack. You will have more hookup with more lugs on the ground but with the power of the motor and being a 136" you still going to spin. Did you look at the IceRiper that one has per mold studs in it. Had one and it did ok.
tileman
Thanks Apex 06 i'll check iceripper out
pro116
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
We (Muffin Works) can offer you the rail/tunnel extensions you need for the mod. The ProAction CK skid works great in stretched format.
heelingcowboy1
Tileman you have a PM.
tileman
Thanks for the replies ,now that i know skid can handle it 136 is were i am going
heelingcowboy1
This is what the rails of a 07 RTX with 136" extensions look like after 1000 miles!!! I actually ended up taking these off (totally tearing the skid apart) 3 times over the winter to straighten and replace hyfax!!! These rails have one 180 mile trip to Tug Hill and the rest is just local riding!! TOTALLY TRASHED!!! And this is just typical trail riding with moguls and stuff---No jumping or anything like that!!! I Also know I am not the only one with this Problem as well soo I don't know why people think that these can handle the added length in stock form--These aren't Mono rails!! So this was my disappointment with extensions--however this sled in extended form is AWSOME!!! But I would either have Muffinworks make you a full length rail that is reinforced or some other way to strengthen the rails--otherwise you will be dissapointed!!
heelingcowboy1
- 147K
- 13K
