bhall80
- Mar 27, 2017
- Cedarburg, WI
- 2017 Sidewinder LTX-DX
2014 Viper LTX-SE
2002 SX Viper
1998 Polaris Indy 600 RMK
I would, but try to remove most of the old stuff first.Popped the seal. Do I add any grease?
And do not put too much grease in, or it will be forced out.
bhall80
- Mar 27, 2017
- Cedarburg, WI
2014 Viper LTX-SE
2002 SX Viper
What brand or kind? Looks like a dry grease unlike the the other drive bearings.
The Isoflex grease like Doo uses in their crank bearings would be good.What brand or kind? Looks like a dry grease unlike the the other drive bearings.
Pop it off. Takes an hour max. Can repack the bearing and clean things up while you're at it.
Byam
If its not done! I would glued this bearing OD and ID whit green locktight.
Bearing , I did mine whit air first. Then brake cleaner amd Lots of Air again .
I always used Blue amsoil full synthetic .
bhall80
- Mar 27, 2017
- Cedarburg, WI
2014 Viper LTX-SE
2002 SX Viper
Would Mobile 1 synthetic work or shouldIf its not done! I would glued this bearing OD and ID whit green locktight.
I use the iso flex suggested above ?
Turboflash
- Mar 18, 2019
- Southern MN
This is a very high-RPM, high-load ball bearing application. I'm not sure Mobil 1 is designed for such an application? I think the Doo crank bearing grease IsoFlex would be a better fit.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
x 2
That bearing is high speed and high heat. I doubt normal grease would be appropriate.
I tried finding another type of bearing for the pto. I believe skf made one but once i told the guy the expected rpm and heat he indicated i better stick with the spec bearing from Yamaha/koyo.
MS
