Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Does engine oil need to be drained to prevent oil from flowing out once the stub shaft is removed?
Turboflash
- Mar 18, 2019
- Southern MN
No. It's a dry-sump engine.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks for your very quick response!No. It's a dry-sump engine.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
All went well with my primary clutch Stub Shaft removal, press apart, press back together with Green loctite, thanks to this site and it’s helpful/technical search tools, and Turboflash’s quick response, and my good buddy Dicky’s press!
Offset measurements before and after, show a 1.25mm difference! Clutch back was not hitting on stub shaft bolts, but it had less space then usual, and offset settings had changed a bit, so now I know!
Thanks again All!
Thanks again All!
