stud pulled through
f7lee
sylvan beach, ny
anyone have a good fix for a stud that pulled through on the outside band of the track, bought the sled used and thought at the time that the studs on the outside might be trouble, and sure enough one pulled through anyone with a fix short of replacing the track
f7iee, There are companys that repair tracks. I had my 04 warrior repaired in fall of 04 after i pulled a stud through in the center of the track, depending on your distance i had mine repaired in the sled . just do an internet search and you will find companies . Butch
Don't worry about it. Shouldn't cause you any problems.
