spark plug
- Dec 20, 2010
hey guys trying to figure out the best studding pattern for my xtx.it has 57 bars so to work out even all the way around pattern in 3 bars then start over again.seems short.would like to have a pattern over 6 or so bars but does not work into 57.what have you guys done.thanks
BADSLED
- May 13, 2004
- Syracuse, NY
- 2025 Sidewinder XTX LE EPS
2012 Nytro MC Xpress 270
Use Woody's 96 stud pattern and you will end up with 114 studs on a 144" track. It's a pattern I used last year and will be running it again on my Cobra track this year. The woody's template is a (6) bar pattern so use it as specified then repeat the pattern again but only use first (3) bars to close off the loop.
