Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Re: Studding
Your's is a good example as to why you should start with less and then add more if needed. Try 96, supertrax thinks you'll be very pleased.SERPAGS said:Don't mean to encroach on your tread, just a quick q.
I have been riding a ski-doo mxz with 96 pins and stock runners.
This year (YES I jumped to Yammi) I am getting the Apex ER and I have been suggested to changethe runners to Woddy:s duallies 6"no studding.
Then someone told me I should get the 6" duallie and no studding.
I ride fast and aggresive, always on trails, lots of wooded trails...etc.
I don't want the feeling that I am riding on a train track, but want safety so that I can ride aggresively enough. Any tips would help.
Tork
Just my humble $.02
Prolly 144, may do 120 but no less than that for me.
I'm too agressive of a rider to go with less, I'll end up breaking them if I do
SledFreak
- Feb 7, 2005
- Ontario. Canada
Re: Studding
96 down the center is all you will need to ride hard in the trail. If you want to drag, then start adding studs and add to the outside belt for drag racing.
MightyWarrior said:Your's is a good example as to why you should start with less and then add more if needed. Try 96, supertrax thinks you'll be very pleased.SERPAGS said:Don't mean to encroach on your tread, just a quick q.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I went to a 1" hacksaw with 144 studs up the middle.
SledFreak
- Feb 7, 2005
- Ontario. Canada
That should give you some extra top end..... Allen, What length of studs are you running?Srxspec said:I went to a 1" hacksaw with 144 studs up the middle.
- Apr 17, 2003
- Menno, SD
- Menno, SD
I went to that track due to the hopes of attending some radar runs this winter. I'm running Woody's 1.075 studs which give betwee 1/4" -3/8" of penetration.
APEX 21
144 down the middle
same hereAPEX 21 said:144 down the middle
STORM-CHASER
144 down the middle on my vector so I am thinking you would want atleast that.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
Does anyone know if Roetin is back to making studs this year? I know they had some issues last year.
Pitt4212
168 studs with 8" carbides up front
STORM-CHASER
[/quote] they were at the SYRACUSE show so I am assuming they are sellingquote="BADSLED"]Does anyone know if Roetin is back to making studs this year? I know they had some issues last year.
GodfatherPC
You guys have pics or patterns on 144 in the middle.Thanks
STORM-CHASER
GodfatherPC said:You guys have pics or patterns on 144 in the middle.Thanks
GodfatherPC
Thansk awesome pic.Did you make your own patern or did you use a templet.
The double backer are they better then single.I'm sorry for all the questions I'm new at this.![Dance 2 LaLaLa LaLaLa](/styles/default/xenforo/smilies/dance_2.gif)
