unpride
How many stud are you guys going with on the Nytro's? I was think 144 with double backers. Will that be enough? 1 per HP so that should be pretty much right on I think
unchained
For traction yes, but for durability no IMO. My experience with 1325 or longer studs is that they bend and break if less than 192.
1 per hp is normally fine, but these things launch hard and the low end torque is the X factor compared to an equal 2 stroke.
lucky_7
I think 144 is the right amount...and coincidentally the same number I put on.
I also had 144 on my rev 800 and never had a problem with 4000 miles on it.
I went with 48 double backers and 48 singles.
unpride
I try to stay away from singles just for piece of mind. I had 144 in my 800X last year and bent a few but the conditions weren't the best. I cant wait to ride this sled I havent been this excited over a sled in a long time!
Singles.... you just need to go with a hard stud like roetin.
unchained
Were they 1325 or longer studs though?lucky_7 said:I think 144 is the right amount...and coincidentally the same number I put on.
clicker_clit
I went with 96 studs and all double metal backers. I had this pattern on my old nytro and had no problems with anything breaking. On my new nytro I did use tall nuts. the stud length is 1.325. 196 is way to many studs in my opinion, and I don't like studding on the outside belt of the track because of wear in the long run. The only reason I put the studs in is to stop in icy corners and on lakes where there is no snow and only ice. I don't like using singles either because they are likely to rip out of the track. I had 144 studs in my old Rev running 60 doubles and 24 singles. I didn't notice any difference between 96 and 144.
lucky_7
unchained said:Were they 1325 or longer studs though?lucky_7 said:I think 144 is the right amount...and coincidentally the same number I put on.
I ran 1.325 on both my rev and now the Nytro. I think a lot of problems people have is simply related to trail conditions.
4bangpower
120-1.325" Woody's Stainless Signature Series studs, round aluminum backers and aluminum big nuts is more than plenty for my FX Nytro RTX even w/ mods.
TurboJamie
Hummm 1 stud per hp, well I guess I need a few more then, I run 192 in the turbo sled and 192 in the nytro. Approx 270 hp in the apex and 200 hp in the nytro.
clicker_clit
4bangpower said:120-1.325" Woody's Stainless Signature Series studs, round aluminum backers and aluminum big nuts is more than plenty for my FX Nytro RTX even w/ mods.
In the past I've had a hard time getting it balanced with 120. I had vibration problems. Have you used this pattern before. I had 120 in doubles.
unchained
Keep me posted on how they hold up.....4bangpower said:120-1.325" Woody's Stainless Signature Series studs, round aluminum backers and aluminum big nuts is more than plenty for my FX Nytro RTX even w/ mods.
4bangpower
clicker_clit said:4bangpower said:120-1.325" Woody's Stainless Signature Series studs, round aluminum backers and aluminum big nuts is more than plenty for my FX Nytro RTX even w/ mods.
I've used 120 studs on a 121" track before and the sled hooked up very well. I had nothing to complain about. I used the single backers and not doubles.
racingronnie
96 up the center with tall nuts. 316 miles no issues yet.
