studs and how many??
Leicester ny
i'm looking to stud my 04 warrior it has and excell exhaust, k&n filters and the stock ripsaw track. how many studs should i put in my track?? and what about tunnel protectors?? i weigh around 380 and bottom out from time to time, this makes me worry about putting on studs!!??
i go about 320lbs. and i just put 108 double backers down the center. 1.4", bought them from rich motorsports. 108 gives you the enough hook-up and braking power without being over bearing and tearing apart the track on a few years. protectors should be there unless you have the aftermarket cooler in the rear, then you have to fab your own.
Studs
Do you have to have a special tool to cut the holes in the track or can you use a drill bit?
Re: Studs
woody's makes a special bit , makes a real clean cut. i bought that from rich also.
