braydene
- Jan 26, 2007
ok jus wondering how many studs you all are putting on and if you need a front heat exchanger protecters
NorthMinn
- Jan 25, 2007
i put 80 studs in. 2 in every row and then i would leave the 6th row empty. But you will need a tunnel protector for the front heat exchanger. The studs hit just behind the heat exchanger when you hitting crossings in the ditch when the snow is a little harder. I dont have them in because i dont know how to put them in.
I run 96 down the middle and not front protection but I have the protectors run all the way to the front exchangers and have no damage after 1000 miles.
4token
- Feb 13, 2007
- Cabot Vermont
- www.cabotskylighters.com
Has anyone tried Gold ice screws? The ones you use in atv and dirt bike tires.
I would think it would work.No more worry about weight, cost, and cooler protection. I may try 3/4 inche long screw. What do you think?
