SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
Can someone tell me where you place supports under the sled when the subframe is removed. Do you need to put weight on the back to keep it from falling over. Pics please if anyone has some. Thanks
Mazz
- Apr 18, 2010
- Esko, MN
- 2008 Fx Nytro RTX 40th
I used two jack stands, one on each side of course, resting on the aluminum plates that sandwich the engine, no need to weight the rear.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
800Thumper
I use two jack stands, with a 3 foot section of thick wall pipe run it between the drive axle and the skid rail tips. Very stable.
i just use my sled lift. why work all hunched over???
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
- 28K
