monsterattak
I am preparing to do my summer maintenance including changing the gear lube and engine oil. My parts guy loves Amsoil. I am thinking of using the synthetic 0w-40 for engine and synthetic 75/90 for the case. He is giving me a decent deal on the oil making it cheaper then the Yamaha stuff. Anyone see any issues or have any feedback.
Also while I am at this of course I am greasing the zerk fittings. I am also replacing all my idlers wheels so i am not worried about those bearings.
Any help on other bearings I should grease and if so are you using a needle to get them? My dealer says everything is maintenance free on the bearings but past experience tells me I should check this out... Thanks for any help...
yamadog1
oil
amsoil is fine to use,i have used for thirty years no problems, on your
drive and jack shaft you can use needle to grease.
sleddheadd
try the new series 2000 chaincase oil here is some info. on it.
Series 2000 Synthetic Chaincase Lubricant (TCC)
AMSOIL Series 2000 Chaincase Oil provides superior protection and performance for enclosed chains. Ideal for snowmobiles, ATVs and general equipment. Extreme pressure additives provide extra wear protection. Extends chain life repels water, and inhibits rust, oxidation and foam. Superior low temperature starting, performance and protection.
monsterattak
Thanks guys..
- 11K
