powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
Nytro with MPI Supercharger stage 1
PowderLites Fuel pump kit and regulator 2 to1
Blowoff valve kit by PowderLites,
Cam timing, Head spacer
Pump gas
220 HP,
http://www.powderlites.com/access.html
Pump gas
220 HP,
Skydog
Hey buddy got her all on and did some riding. The wot is GREAT!! But at low rpms it runs bad. I do not have the bov i am thinking that is why. What you think?
thank you Skydog
thank you Skydog
dilley
skydog, let me know what you think of the rb3. i am not happy with the gems programing. my app will be a little diff cause i run @ 10000+ ft., but the tunability and the ability to have more adjustment points is what i am looking for.
Thanks, Dilley
Thanks, Dilley
Skydog
Will do! But i know it is going to ROCK!!
Skydog
Skydog
Skydog
dilley said:skydog, let me know what you think of the rb3. i am not happy with the gems programing. my app will be a little diff cause i run @ 10000+ ft., but the tunability and the ability to have more adjustment points is what i am looking for.
Thanks, Dilley
Get it!!!!!!!!!!!!!!!!!!!!!!!!
It rocks!!Skydog
powderlites
- Sep 5, 2005
Nytro Supercharger Stage 1
Feb. 23/08 FX NYTRO MPI Supercharger Stage 1 with PowderLites fuel system, Head spacer, Cam timing, Blowoff Valve,
2 bar Map sensor
Tuning Bike map on Top end and it's a good starting point for lower end throttle response.
2 bar Map sensor
powderlites
- Sep 5, 2005
MPI Supercharger Nytro Stage 1 with head spacer, cam timing, PowderLites fuel regulator & pump kit.
Load setup is on the bottom in map details.
Make sure you setup load for 2 bar map sensor.
Made map on March 3/09 Owlshead Sicamous, BC
Skydog
Nice the key here is the 1.39 min volts!!!!
Thank you Skydog
Thank you Skydog
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
what do you think a mpi stage one is worth used and what would it take to make it run right at sea level on pump gas as a trail sled???
- 37K
- 6K
