yamahacat69
mpi supercharger nytro anyone know at sea level 26 bottom 28 top what that should give me boost # and if i go 27 bottom what with be the increase thanks
Support@MPI
TY Advertiser
- Feb 24, 2015
- Yamaha
26b-28t= 5lbs 27b-28t= 7lbs @ sea level
Luke600r
- Jan 20, 2015
- Wi
- Yamahas
What would a 27/27 be26b-28t= 5lbs 27b-28t= 7lbs @ sea level
scuba_nytro
- Feb 1, 2011
- 2009 Nytro RTX MPI Stage 1, Hindle Exhaust, Evolution Re-flashed ECU, Ulmer Clutch Kit, Split Rail Skis, etc.
6 lbs
scuba_nytro
- Feb 1, 2011
I run 27B 28T and see 7 psi no problem 8 cold days boost gauge is hooked up on throttle bodies.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I have 25 Top, 29 Bottom. It will run 12#
Fastfewest
- Jan 4, 2019
- Montana
- 2010 Yamaha Nytro
What would boost roughly be using 23T bottom and 31T top at 4500ft.
full tilt viper
- Dec 25, 2009
- Nytro MPI Stage 1
Alot 12-14
