corv65
Sorry, I know I've seen suggested changes to the suspension on a Vector when you change the skis but can't find it. Thing drives like a truck since I put the skis on: Simmons Flexi with 6" carbides.
If I remember correctly; soften up the shocks as much as possible and move the transfer rod adjuster to almost MAX. Did I 'member right? Do you need to change the other suspension adjuster??
Thanks; great site!!!!!!!!!
lenman20
- Mar 20, 2007
- merrimack nh
- 2005 rs rage
lossen limiter straps and put transfer rods so you can see 2 lines this should lighting up your front end. dial transfer rods in on the trail
