Sway bar ?'s
tdog1225
Waterloo,IA
I know there's threads in here about the sway bar removal but don't want to spend hrs trying to find. I know it's a pain to remove, and you can unhook one side for better control out west. My problem with this Is I don't like the fact of that the unhooked side faces forward and can catch on stuff. Can I unhook both sides and roll it backward and zip tie it up? If I do this what works best to compensate for the body roll? I ride trails and go out west. I don't know much about shocks and I don't have floats. Is it as simple as to tighten up the spring?
Yes you can simply tighten the spring to increase the preload. However for riding out west I would not worry about that. That is more for guys that run without a sway bar on the trails. if you are going to run the trails without it then yeah tighten the preload.
I run without one trails and out west. You just have to be a little more active in the seat on the real twisty stuff.
Sorry I can't help with folding it backwards I took mine all the way off as soon as I got the sled.
Would like to know how to take it off or quick mount back?
You can remove it w/out cutting it, it takes some time and patience but it can be done. Also unhooking one side and riding it is ok, did that on my XTX for a couple rides to test the changes before I ended up removing it.
