switching from nitrous to turbo
wantboost
upstate ny
well since my season is over and 1 cylinder is down to 80 psi i think it's time to rebuild and put some low compression pistons in.first how hard is it to pull motor and rebuild.2 what kind of pistons are you guys using and where do i buy them.are you putting rods in also?is there a stroker crank or bigbore avalible.how many headgaskets with low comp pistons?is there head work that should be done (ie porting,bigger valves)just want to make sure i do it right while it's apart.
If I was in your shoes, put in the JE Pistons. They make a 9 to 1 piston, and 1 head gasket. Instead of stacking 3 gaskets or head shim to get 9.4 to 1, or like some do 10 to 1 with 2 gaskets to get 9 to 1.
Brother there are a lot of questions youre gonna need answered in the future. The best thing for you to do is search and read as much on this forum as you can. When you get to a question that you can find the answer to then ask it and you will get some good answers. But leave the FAQs up to the search function is possible.
Good luck and welcome to the Boost club! :Rockon:
