FastAction
ok read this one a few times and still a little fuzzy.Can I run pump fuel(94) and go to 12 lbs boost.Running three yammi headgasgets. Or will I need to mix in some c12.
Buckeye
- Lakes Region, NH
I would not exceed 10. But then altitude comes in to play.
octane
minus 2 points of octane for every 3000 ft elevation is the rule.
but I would rather be over by a point or so than under
Jack_Shaft
Wow, I haven't been on here in a while and this thread really developed into some good info. I will re-read and then post comments, my block will be back soon and my RX-1 turbo will be up and running, so I need to refresh my memory.
-JS
-JS
