Just wondering if there are any pros or cons to breaking in a new motor with synthetic oil or should you break it in with convensional oil?
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
i break mine in on 4S and then after 1000 miles go to MOBIL 0W30
Iceman56
Don't use synthetic oil to break it in, it is to slippery and won't let the rings seal completely.
johno
What he said
Just broke in the motor first 300 with conv oil now going to 0w30 mobil.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
i broke mine in after the new build with 0w30 yamalube semi....then after 600 miles went to synth.
you guys running mobile 1 0w30,you should realize the zinc/phos levels in those automotive oils is very low. good discussion here:
http://www.ty4stroke.com/viewtopic.php?t=77213
Dan
Dan
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Broke mine sleds in on the factory oil, then went with Yamalube 4S 0w-30 everafter. I run it because of availability and price, also because the shop manual what me too LOL
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
We brake in a Niki'ed cylinder on synthetic because the rings don't really need to cut the cylinder walls.On iron bores,we brake in with conventional oil to allow the rings to cut the tips off the cross-hatch.Then we switch to synthetic oil fortified with zinc if possible
