Tach signal wire - RX
lakercr
Tech Advisor
Winnipeg, Manitoba
I'm going to hook the data logging feature from an FJO controller up so that I can dial in the jetting with my laptop. The wiring schematic suggests the Yellow/Black wire is signal. Is this what you guys have been using, or are you taking the signal from a coil?
The yellow/black works on a VDO style tachometer gauge, but when using the Hot Tach Pro you have to tie directly into the orange wire going into one of the coils. I am not familiar with how to set it up with the FJO though. Give me a call if you have any questions, I'll be in the shop until about 4 PM. 605-387-2833
Thanks Allen. The FJO just needs an analog signal. I'll give you a call later, have a few things to go ever.
