D&C&S
- Feb 6, 2017
- N.S.
- AC 7000
Hi. Just joined. The tach on my 2015 7000 AC only increases in 50 rpm increaments, like 1500-1550-1600-1650 and so on all the way up. Wonder if this is right or should they be smaller like 10.
What are you guys seeing on your Vipers. Thanks.
Crazy Canuk
Same on my '17 Viper. I think anything less and you probably wouldn't even be able to read the numbers as they would be moving/changing to quickly.
mtcooler
- Dec 16, 2013
- Newton Wi
- 2014 ZR 7000 LTD Sno Pro
Moves by 10.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Mine is by 10.
trailtamer
- Feb 8, 2006
- Manistee County, MI
- 2014 Yamaha SR Viper LTX
10 rpm increments here.
D&C&S
- Feb 6, 2017
- N.S.
- AC 7000
Thanks. I thought it should be 10. Everything went south after i had the reflash done my tach reads in 50ths and my speedometer is 25% slow. Now I have to convince the dealer it's their fault.
trailtamer
- Feb 8, 2006
My speedo was 25% slow also. I Bickered back and forth with the service manager about this same issue. They were trying to tell me that the last reflash didn't screw up the speedo and reflashing it again would not fix the problem. I insisted they try it, and................ta da!!!! speedo is correct as per gps. Insist they reflash yours.
D&C&S
- Feb 6, 2017
- N.S.
- AC 7000
My dealer did the reflash for me again and it fixed the speedometer,now reads right on.
Tachometer still in 50 but I guess some are like that.
TILAM1
- Jan 26, 2017
- 2017 SR Viper R-TX-SE
- Eastern Ontario
My 2017 R-TX-SE reads rpm in 50 increments. I'm going to check the speedo with a gps today.
TILAM1
- Jan 26, 2017
- Eastern Ontario
Did a run today and the GPS matches the speedo pretty close.My 2017 R-TX-SE reads rpm in 50 increments. I'm going to check the speedo with a gps today.
yamajammer76
- Apr 6, 2005
- Black Hills, SD
- 2024 Arctic Cat Riot 600 1.75
My 2016 reads in 50 increments. It did before the flash and after. I haven't rode it since it was re-flash, but since I waited until now to flash it hopefully my speedo is accurate.
D&C&S
- Feb 6, 2017
- N.S.
- AC 7000
It seems that some tachs read in 10 and some in 50. That will not change with the reflash but on some (the early flash)
It was screwing up the speedometer. If you get the flash done now I think it should be OK.
