DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Wish I had done this years ago! I had too much time on my hands with the lack of snow and ice! I found a basically brand new kit and was able to grab it at .50 on the dollar and was able to keep my stock turbo.
I was concerned that there would be alot of turbo lag as I've driven one which had crazy lag. I was pumped after first pulling the trigger to find that it felt no different than my stage 6 stock turbo winder.
I did the install myself and the kit from TD went together very nicely. The toughest part was installing the coolant line from the oil cooler to the turbo. The injectors went in really easy. Having never done injectors before I was a little worried but it's really quite simple.
The additional power was quick to hilight weaknesses in my clutching which I believe I have now corrected.
I'm so looking forward to next winter and trying to get this beast as fast as I can in 1320'.
Heres what i can say so far.... It would take a perfect day with a light weight driver to get over 140 in 1320' on my pump gas stock turbo. The big turbo with me on the bars at 205 lbs naked runs north of 140 in 1320' every pass on pump gas.
I'm limited on how much boost I can run as I don't have a built bottom end (yet).
For this dragy run my datalogs showed 4 seconds to 100% throttle. Basically rolling into it pretty easy while i get it dialled in. Trail track as well.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
They work very well . Lots of potential now .
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Cant wait to see what you post up next year! Your gonna end up warp speed traveling back in time haha
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Are you strictly going to only run pump gas? I'm curious what feeding it some significant octane yields.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
On race fuel it is quite a rush.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
W O W
DMCTurbo
- Nov 12, 2005
I need rods and pistons to take full advantage of the turbo.Are you strictly going to only run pump gas? I'm curious what feeding it some significant octane yields.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
What does TD run on their tunes for boost on the big turbo ?
DMCTurbo
- Nov 12, 2005
I have 5 tunes. MS17 trail, MS20 trail, both have knock protection. 20, 23 AND 28 PSI race tunes with no knock protection. With the boost timer you can add up to 20 PSI.What does TD run on their tunes for boost on the big turbo ?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Whole different approach than the other tuner. Cool
Recommended rpm ?
Recommended rpm ?
DMCTurbo
- Nov 12, 2005
92-9600Whole different approach than the other tuner. Cool
Recommended rpm ?
Kenneth Rogers
- Jan 23, 2019
- Fort McMurray, Alberta
- 2021 Sidewinder SRX LE
2018 sidewinder xtx-se 137”
1997 Vmax 4 800 shorty
1996 Vmax 4 800 shorty
1995 Vmax 4 Improver
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
Did you have to do head studs on that setup?
DMCTurbo
- Nov 12, 2005
I had already done head studs when I went stage 6.Did you have to do head studs on that setup?
Kenneth Rogers
- Jan 23, 2019
1994 Vmax 4 St
1993 Vmax 4 800
1990 Phazer
1989 Bravo
1980 SRX 440
Thanks! I want to do this next season possibly. Head studs are the one part of the setup that causes me a little hesitation.I had already done head studs when I went stage 6.
