AttakSnow2
- Aug 17, 2005
- Merrill, WI and White Pine, MI
- Yamaha Viper
Please help!
use straight angles with it I run a 34 degree on the rx1 and vector and this seems to trail ride the best with the best fuel mileage. I run a 125-175 spring. I have tested different angles and allof teams helixs they have told me and I was disappointed in the peformance of them.This year I am going to get more straight angles to test with. hope this helps woodtic
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
woodtic said:use straight angles with it I run a 34 degree on the rx1 and vector and this seems to trail ride the best with the best fuel mileage. I run a 125-175 spring. I have tested different angles and allof teams helixs they have told me and I was disappointed in the peformance of them.This year I am going to get more straight angles to test with. hope this helps woodtic
What about a 46/34-F ~ 48/34-F and Red/Dk. Blue spring (not sure of rate)???
Hey 4fighter give it a try, I have a 48-38F and it not to bad. I really like the straight angles better now. I just put a polaris clutch on the vector and it really helped the vector out. It really helped the top-end onit. Im starting to think that the top-end problems with these sleds are in the primary clutchs. The belt runs cool and comes all the way up to the top of the clutch. I have been running it against our attack and before the attack would pull it all the way. now the vector will run with itmost of the runs at the middle and top-end. You guys got any snow up there. woodtic
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
woodtic said:Hey 4fighter give it a try, I have a 48-38F and it not to bad. I really like the straight angles better now. I just put a polaris clutch on the vector and it really helped the vector out. It really helped the top-end onit. Im starting to think that the top-end problems with these sleds are in the primary clutchs. The belt runs cool and comes all the way up to the top of the clutch. I have been running it against our attack and before the attack would pull it all the way. now the vector will run with itmost of the runs at the middle and top-end. You guys got any snow up there. woodtic
I thought about it, then decided NO! The sled is plenty fast, and the clutching aint too bad. I listed the TEAM in the classifieds.
