The aftermarket bearing #'s that get installed shock side??
downlow
Lapeer, MI
Im in need of the bearing numbers that get installed((aftermarket)) that keeps the track from rubbing or hitting the shock on the Apex's when studded fully across the track..thx in advance.
ROCKERDAN said:
mine lasted 50 miles,the bearings cracked due to stud heads hitting the bearings....so i updated to what the 09s look like..
see here:
http://www.ty4stroke.com/viewtopic.php?t=78847
dan
Hey dan those small wheels that fix has on there site are listed for 99 bucks,is that for 4 wheels and shaft or just for the two,i am interested in the two inside,so i dont need the shaft type,but would like more info about the way they mount up on the inside of the rail. thanks pete
FPS sells two marginal wheel kits for the mono apex...(and maybe other models too)
-Mid wheel kit(no shaft due to transfer rod)
-front wheel kit(solid cross shaft)
these kits come with everything needed to stop hyfax wear in the TWO areas known on the mono to wear thru quickly(at the bend and mid section)
each kit is sold separate for $99 bucks from fixpowersports,if you call them direct to order they will help with any questions....the kits i got 3 season ago now,have held up perfectly....you need to use locktite on the installation and be sure to keep an eye on them so they do not come loose,mine have been fine since day one. there are clear directions in the kits on where exactly to mount the kits,as FIX has much experience with the hi wear locations.
recently i found(after two seasons) that two of my bearings were alittle slow when spun,so I found i can order the 2.75" wheels separately with the replaceable bearings...you could get just the bearings too if your wheels hold up,so far my wheels look perfect after 2 seasons.
royal distributing in canada sells these wheels page 168:
http://www.royaldistributing.com/main/i ... Number=168
also mfg sells them here:
http://www.mfgsupply.com/m/c/04-116-62.html?id=s3omuvbq
FXP site here...they only show the mid wheel kit but i recommend both kits for sliders that last forever(just call them to order)
http://www.fixpowersports.com/pages/cus ... l-kit.aspx
Hope this helps
dan
